I noticed a lot of strange artifacts in the darker gradients on the monitor. It's like wave or circular shapes that seems like to split the gradients. It's hard to explain but any idea what this may be caused by? At first I thought it was my driver's but I think it may be the monitor ?
specs:
MSI Optix 27" WQHD 144Hz
Gigabyte rtx 2070 super oc
cable: displayport (stock cable that came with monitor)
attempted fixes that didn't work:
1: https://www.google.com/amp/s/windowsreport.com/nvidia-color-banding-fix/%3Famp
2: fiddle Ng with nvidea control panel color setting (made it worse so reverted back to normal)
3: removed NVIDEA drivers - Still banding
4: reinstalled NVIDEA drivers then override stock settings - still banding (kinda feels that its slightly worse)
5: installed the drivers for my monitor with the updates ones from MSI - No change
6: Changed display port - port. No change
(I really do not find anything more useful on google either, so would be a big help if someone knew anything that could fix this because i really do not believe a brand new MSI Optix MPG27CQ and RTX 2070 Super is supposed to be banding this much, right now youtube and netfflix is even unwatcheable it really ruines the experience and gaming is difficult because all dark areas are pitch black and really cannot see the way im supposed to.)
Snapchat-882704721.thumb.jpg.b97a85b1c2f09e22993823e409a9274e.jpgSnapchat-1323590066.thumb.jpg.ab574c6d6835df002ca38c9206e1039c.jpgSnapchat-1354330561.thumb.jpg.c519135f7b09f4642cd4d907ebeab2da.jpgSnapchat-449108501.thumb.jpg.eada1915d2e61822e8caeb30fc8f0279.jpgSnapchat-1951055155.thumb.jpg.221374d919391f6c361b8b7e9241ab33.jpg
https://linustechtips.com/topic/1132137-strange-artifacts-on-monitor/
Thats normal. It because it can display the colors in between. Its a software thing happens a lot in youtube video's for me.
Its called banding. Google it.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
I googled it. It most certainly fits the bill ... It's so annoying its present on YouTube netflix and in most games... Any efficient solution to this ?
Only thing i can think of is turning down brightness and stuff so its to dark to notice. And yes i got the problem too.
I do want to go for an HDR monitor some time, but im not sure if that will be a solution since its in the source afaik.
I see. I did turn monitor brightness down and such. But then it became too dark for my games haha.  But I found this article I am going to check out to see if there is anything useful https://www.google.com/amp/s/windowsreport.com/nvidia-color-banding-fix/%3famp
Ok I think that is not normal however...
What sort of displays have this?  None of mine have this. No offense,  just curious!
PS: wait you say software,  so it's not a display thing... ?
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Quote
tones were being displayed incorrectly regardless of the monitor settings or graphics settings, so users concluded that the only possible explanation would be an issue with the Windows 10 May 2019 Update.
This claim is further backed by the fact that some users found that a clean reinstall of the OS, but only up to the 1809 update, solved the issue.
I guess that explains it as I'm on 1809...
I still don't think this is "normal"!
What the hell, there are so many issues with 1903/09 how did MS not pull this yet from public?
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Cus they clearly dont care.
Have a source for this so i can look into it cus ive been having the issue as well.
Looks like it....
Yes, sure, has already been posted though.
I would probably read this very carefully and try do apply the fixes they suggest - as it appears to be fixable actually,  it just seems like a lot of trouble to go through,  still worth it probably :o
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Looks like it....
Yeh I am gonna check that out too :) alsalso for reference I got a MSI Optix 27" WQHD 144Hz.
