Molex To 6 pin adapter
thdevi
Can you specify your PSU?
Personal Desktop":
Luna, the temporary Desktop:
If your PSU only has a single PCI-E cable, chances are this PSU won't be happy about running a GTX980.
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
Those work as long as the PSU has enough juice
Builds:
2x molex to 6pin is better than 2x sata to 6pin
Most people will tell you no, to get another PSU.  If your PSU will handle the rated wattage of your system, and you have 2 molex available - Id do it all day long but then again Ive never blew anything up in 20+ years of doing this stuff so none of it scares me.  And Ive done some jank sh*t
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Never use an adapter like the in a system you care about, if your PSU lacks the connectors then it's inadequate for the job.
Primary PC:
Well I Just smacked my case with a hammer to get the gpu in
Eh, if it works it works - I play around with a lot of older hardware and enjoy finding out what works, and what doesn't.  So far my luck must be 100% awesome in 20 years.
5 minutes ago, thdevi said:
my brother does it fine but i want some advice before i do
While not entirely advisable and you will be more subjective to a failure, using a molex adapter will work.
Personal Desktop":
Ok I Know My PSU Has Enough Power Just I Dont Have The Money Right Now To Buy A New PSU It Will Only Be Temporary
