Can I connect a fan header to my mother board then another fan connected to the first fans molex cable?
Solved by minibois,
That molex connector is like not 'power out'.
Get a couple fan headed splitter cables to run two fans off one slot (you can possibly run even more than two on one headed, but just double check the amp going through those headers and the amount your fans use).
Featured Topics
maka0 ·
Posted in Storage Devices2 -
3
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning5 -
Xrniu ·
Posted in New Builds and Planning3 -
8
3
