Dark rock slim or noctua nh u12s for ryzen 3700x
4 minutes ago, Mateus Montemor said:well, i knew about the difference in sizes hahahaha, but both fit my case, i was asking performance wise, maybe ill go for the u14s, same price as the dark rock slim+shipping, and just 3$ more than u12s, only thing is that on the future i might buy a black noctua fan because those browns... hahahah thanks for the help
Ah sorry, yes sure it will perform a bit better and more silent. The 140mm will have to turn at less RPM to move the same volume of air. Also the cooler itself is bigger = same perf at lower RMP for the 14
and yes... maybe you can try to sell the included ones and get Noctua cromax fans. They are the same but black
also noctua has some black and colored shrouds for the coolers wich Look nice
this: https://noctua.at/en/products/accessories/heatsink-covers/na-hc5-chromax-black-swap?___from_store=de
