Need HELP, new pc smells burned
Solved by NewUser99900,
44 minutes ago, Lightsilent said:Take ram out and place back in. Reset bios. This might fix the issue.
I started my system new After a while with only the cpu, mobo one ram stick and aio and it worked very good. Probably the lad's of the fans alls where burned down as I realized that the light does not turn on. Hopefully it will all work when I connect the other 24gb of ram and the gpu
Featured Topics
joe_ollie909 ·
Posted in CPUs, Motherboards, and Memory6 -
DreamCat04 ·
Posted in PC Gaming0 -
saltycaramel ·
Posted in Tech News2 -
4
1
1
1
VinSen ·
Posted in New Builds and Planning4
