Wifi Card for Gaming PC?
Trippsy
(I hope this is the right category)
Im looking to get a wifi card for my gaming PC mainly to help with ping and better connection. The way my house is set up I can not use the tried and true Ethernet so unfortunately on board Wifi or a card/adater is all I can do right now.
Suggestions?
Motherboard: MSI MPG x570 Gaming Plus
Case: NZXT H500
Have you looked into a powerline adapter? It would help a lot overall.
Primary PC:
No, what is it?
I personally use a Gigabyte GC-WB1733D-I Wi-Fi card, it's a PCIe x1 Wi-Fi card that supported 1733Mbps and Bluetooth 5.0. I bought mine for £28 from Amazon.
It's been super reliable so far in my experience with it, no ping spikes, no outages, no malfunctions, it's a great card.
The reason it's a good card is because it uses an Intel 9260 Wi-Fi card as it's method of networking, meaning you get Intel networking inside the card, great reliability.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
4 minutes ago, Trippsy said:
No, what is it?
it's a wifi extender, you run an ethernet cable to it and it gives more range.
Primary PC:
If it's an internal card, as long as it uses Intel's Wi-Fi chipset, it should be rock solid. Though make sure the antennas can be in a position where they're not blocked a whole lot by the case itself since the case can act as an RF block.
However I've used USB based ones in the past, which 3.0 ones are still good for 802.11n and 802.11ac. Do not get a USB 2.0 one.
Suggestions?
Case: NZXT H500
Should have bought a motherboard with wifi instead of that X570.  TP-Link's products are good.  Basically most every wfi solution works fine just need to get one based on your internet speeds and distance.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Best Wifi for a desktop is getting a motherboard with it built in, otherwise try Powerline Adapters they're fantastic. If you can't do powerline adapters then any pcie wifi card that uses intel chipsets and is wireless ac, I used a gigabyte one last year for a friend that was pretty good can't remember the name but I think it was only like $30 on Amazon.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB  |
TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD |
Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB |
How so when a PCIe to M.2 adapter will basically allow identical chipsets as provided on-board?  The only benefit of on-board is the USB being routed in the connected rather than stealing a motherboard header. eg https://amzn.to/32lbDae
The bonus is they could easily be upgraded to an Intel AX200 card for the very latest WiFi 6 technology for less than buying the higher model.
Powerline can be a good option if your AC wiring is good and you don't have DSL, but its also more expensive than WiFi. (it can interfere with DSL in some circumstances causing a reduction in broadband speed)
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Well then you're having to buy an adapter as well as the WiFi card. With a board that has it built in you don't have to buy extra parts or adapters and you aren't taking up slots that can be used for other things.
Fair point, but depending on the motherboard choices you could end up paying more than the cost of the adapter and most people will have spare PCIe slots anyway.
It only really bites you on the ass when you go ITX like I did ;) so have no spare PCIe slots.
Well technically my motherboard DOES have on-board WiFi, but its soldered on the board so can't be upgraded which sucks.
