Best RPM/£ case
Faisal A
I am currently building a new PC and want the most powerful cheap fan I can get. It does not need to be a premium brand like Cosair or NZXT, any cheap Chinese one will do. I dont want to spend more than £15 for 2 fans.
If you want me to see your reply, please tag me @Faisal A
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Do they need to be 120mm or 140mm fans?
I've personally used UpHere fans in Blue Build 2018 (signature) and they were good for the price.
https://www.amazon.co.uk/dp/B07BK2PJSN/ref=twister_B07S7HSR97?_encoding=UTF8&th=1
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
On 6/3/2019 at 2:49 PM, Faisal A said:
I need something that gets to 2000-3000 rpm
? Are you looking for jet engine like sound? CFM at a given fan speed is more important then maximum fan speed, lower end fans usually need to spin faster to have a good air flow resulting in higher noise for the same performance.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
2 hours ago, Faisal A said:
@Mathieu9836 I dont care about noise, it just has to be cheap and powerful
Then get the cheapest fans on pcpartpicker with the highest CFM you can afford, the higher the CFM the higher air volume they can move at a full speed, but 3000rpm will be very noisy i would suggest getting decent CFM  with low noise level or more lower CFM fans, Rosewill make a cheap 4 pack 120mm fan but they are only about 30CFM, you pick 2 packs and put as much fans as your case allow. Thats the very budget solution.
