Best 2 Slot Video Card For $500 or Less?
Solved by SenKa,
3 hours ago, XR6 said:EVGA Black RTX 2070 is probably the best 2-slot card you'll find for under $500 without MIR.
If you don't mind using MIR you might be able to buy an EVGA XC Gaming, Aorus or ROG Strix card (although iirc some Aorus and Strix cards aren't 2 slot).
I think I will go with the XC Gaming, as it is a true 2 slot card and looks really good to my eyes.
Thank you, theres so many options!
