Will Ryzen 7 2700x work on X370 chpset?
Solved by Princess Luna,
4 minutes ago, Amforev said:@Slottr @Minibois@Princess Cadence @_d0nut
What about Athlon 200GE is it considered as Zen+ or Zen architecture CPU?
It's the original Zen 14nm so it'd be compatible in case you need to use one to update BIOS, although you could also always take it to a local store? either ways good luck!
Featured Topics
Cramig88 ·
Posted in New Builds and Planning1 -
Ghostsanonymous ·
Posted in Displays3 -
1
halfbood_drag0n ·
7
13
1
