Cryorig h7 for i7 8700 under heavy load
Solved by Brooksie359,
1 minute ago, Quzzu said:That's what I thought. I just saw lots of people saying their cpu runs too hot
They are probably overclocking or using the stock cooler. The stock cooler might as well be for display because it is inadequate. For overclocking it certainly can run too hot even if it isn't extreme. At stock it shouldnt be a problem and it will adjust the turbo if it starts to get too hot.
Featured Topics
