Questions for airflow. Positive or negative for low energy processor.
Go to solution Solved by Sakkura,
Doesn't really matter with how little power it uses.
36 minutes ago, Kooeunbam said:
I am using low energy processor, intel J5005.
I am wondering will positive airflow would be better for low energy cpu or negative airflow is?
Maybe i can try neutral airflow if i use gluegun :)
What do you guys think?
This should be good... uhm gluegun?
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
Doesn't really matter at all. As long as there's airflow going on, it stays cooled. "Pressure" only effect on dust built-up around the case.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
