I'm still looking to find that Linux distro that tickles my fancy if you know what I mean. I currently use windows 10, and will continue to do so. I'm most likely looking at duel booting since overwatch doesn't run 100% the same as windows in terms of performance. I also stream and im sure streamlabs doesnt work on linux. Besides all of that the main reason I havent switched to linux has to do with the fact I feel "naked" using it. Windows is such a mess that it feels weird using a clean os. I'm not new to linux either. I'm proficient at using command lines. I currently have tried linux mint, Ubuntu, element in the past to try and switch to linux. If you have any suggestions for linux distros i should try please let me know.
https://linustechtips.com/topic/1044004-help-choosing-linux-distro/
ubuntu, I ran it off an old 80GB ssd for a while. great for learning linux imo. After you get used to it, mabye try a different one like arch linux
I like 16.04 LTS, but 18.04 is good too. IMO, only get the LTS ones, and stay on it and don't download the newer versions, just bug fixes.
For general purpose, Ubuntu is very good.
16 minutes ago, TRraven said:
linux distros
The solution is easier than you think.
Decide what programs you wish to try out under Linux, see which Distro is supported, then choose that one.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Right now my favorite is just plain Ubuntu 18.10.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Well what are your issues with the distros you've used? I mainly used Ubuntu and Mint but I've tried a couple of other ones just to see whether I would like them more, but I always ran into problems with stuff that I could easily do with Ubuntu and Mint (though this is probably more because of my lack of knowledge than the os). You could have a look at CentOS I guess.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
Probably best route is load an decent size USB say 16GB with several distros that can live boot.  Then proceed to try each out without needing to directly install or dual boot.
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
