Monitor upgrading Questions
Nickonil
Go to solution Solved by Brooksie359,
1 minute ago, Nickonil said:
what would you say is the main difference between these two and for a gamer what would be the best option while still getting those sweet colors?
https://us.msi.com/Monitor/Optix-MPG27CQ
It has a va panel. Idk what msi is using to measure response time but from my understanding even the fastest va panels have shit response times. I would personally go ips over va and opt for the Acer monitor I showed.
hey, so i have a "AOC 27" LED FreeSync G2770PF" and a older "AOC 27" LED g2770pqu" both are 1080p and have 144hz
(complete side note: i have no clue if i can use the freesync with my 1080TI
now both basically do, what i want.. BUT i have had them for 4 and 5 years.. and i want something "new" and more fancy..
what i am looking for is better colors, while still allowing high frame rates, i am willing to go down all the way to 100HZ maybe even a little lower, but 60 is too low for my taste.
what will the "new" screen be used for, so as to know what would fit me?
well i am watching twitch, so twitch chat needs to be readable (TEXT) also i read on high contrast backgrounds like the Linus Tech tips forums, so no burn in is important (if thats still a thing)
FPS gaming, general gaming, well.. to say it like this 12+ hours every day 7 days a week gaming.. second screen is to watch people play while i play so i dont feel alone :P
my pc specs are decent i have a 1080ti and i7 6700k(watercooled)
when it comes to pricing i would like to believe i can reach for the upper price range or at least middle upper, but i wouldnt scoff at "upgrading" to a budget monitor if ya'll think it ticks my boxes (witch i dont belive)
So you don't need a better monitor, you just need to tweak the settings on the ones you have.  It's not like you need IPS for editing or content creation.
"to say it like this 12+ hours every day 7 days a week gaming.. second screen is to watch people play while i play so i dont feel alone :P"
Uhm, I know you said it tongue in cheek but that's just kind of sad. Maybe work on being social?  And before you say I'm being a dick and it's none of my business.. you put it out there first.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
well.. that was just ment as a joke.. and to break the tension if there was any... however my question still stands.. i am looking for ideas/recommendations..
Wasn't tension before, but now... :)
There a a ton of 1440p 144/165 monitors out there that will love your 1080Ti.  Or even move up to an Ultrawide?
What size and budget are we talking about?
Not sure what you believe to be the upper range, and believing you can reach it never helped my wallet much :)
OnePlus:
Other Tech:
budget 700-1400 USD can go higher aswell
Size?  27, 32, 34, 35?
OnePlus:
Other Tech:
27" is okay, but i am open for 24" aswell
2 minutes ago, Brooksie359 said:
https://pcpartpicker.com/product/ttnG3C/acer-monitor-xb271hubmiprz
This would be a good option. Ips for good colors and contrast while having 165hz refreshrate allowing for ultra smooth gameplay. Also 1440p is nice for extra crisp visuals.
okay i will keep that in mind :) i think i will need to test these 2 out myself because i am really sold on both of them :P but if i cant physically see them i will go with what you said :)
I’m in the same boat and the ASUS ROG Swift PG279Q 27"165Hz IPS G-Sync Gaming Monitor is what I am saving up for.
I play Rocket League and Skyrim so need a good balance of response, refresh and pretty colours.
I could cheap out and get the TN version.
Reviews are solid across the board.
i5 8600 - RX580 - Fractal Nano S - 1080p 144Hz
if you go tn you dont get the vibrant colors but you get the better response time.
@Brooksie359 I’m too old to make use of the TN response time these days, also I’ve had TN monitors since I retired my UHR CRT, those were the days!
Time for me to finally experience something new and move to IPS, even for eSports games like CounterStrike and Rocket League.
I’ve had 144hz monitors now so I’m not going back to 60hz to go 4K so the monitor I chose is my ideal sweet spot.
I have the pg27uq so I can have my 4k and 144hz in one monitor.
Lucky you! If you can afford it that is the monitor to go for.
I couldn't even afford the card(s?) to drive that.
I love the monitor and it looks amazing. That being said I still play on my 1080p 240hz monitor that I got for 400 bucks far more often mostly because I play alot of overwatch.
