My first build ,how bad is the cable management
step40
I am finally done with my first build.That was the hardest thing ive done in my life for real.It took me like 24, 25 hours. I made so much mistakes.the cables were the hardest part.I had to remove fans and components like 10 times because of my mistakes (decisions) .So that how it looks at the end.Do you think the cable managament on the front is bad?I wont post the other side of the case because i am going to get banned probably lol (closed the case panel hard because of all the fat cables).
Not even that bad, or at least not nearly as bad as my first rig. Now all you gotta do is post your specs in your signature like us master race pros
Primary PC:
Would look better for the 24 pin and 2 gpu cables to come from the gap to the right of the mobo, then run the front panel cables through the back and emerge through the same slot as 24 pin, just lower down. Cables running from the left of the mobo could run down and hug the bottom of the first pcie slot, the gpu heatsink would conceal them well. +1 for getting a power supply that doesn't use ketchup and mustard cables. Looks good for a first build
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Thanks for the feedback bro
Nice outcome, glad to hear you got it up and running smooth. Looks really good too! Just move the motherboard power cable and you got a good looking machine there.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
Hey Matey, welcome.
And Good job there.
My first few PCs, were shambles because I didn't care for managing cables (beyond basics)
Thats a nice looking system, and shots of it are well done. Congrats on the first time build, expensive Lego can be stressfull but not so bad now is it. Fruits of the Labor, Good Job
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
