Monitor flickering when displaying darker colors.
thebaguette
Hello,
My ASUS VG245H 75hz monitor appears to have an odd flicker when displaying darker colors such as grey. It is especially noticeable when using Steam. Does anyone know how I can fix this?
Could you upload a video of it?
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
I have tried that but it is very hard to capture on video because it's not like it's flickering on and off. It's similar to when a light bulb is dying and it flickers very quickly from dim to bright.
Ah. It may be an auto dimming feature. Some monitors and TVs have features to dim down on darker colors (not sure why anyone would want that). Look through your monitor settings for something related to this.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
I have checked my monitor settings and there seems to be nothing there. It might be an issue from the factory because I have two of these and only one does it. Also the way I worded my previous reply was off, sorry for the confusion. What I meant was it was constantly flickering like a dying light bulb, and it's weird because the brightness of the flickering color doesn't change, it's almost like it's jittering.
