Search In
  • More options...
Find results that contain...
Find results in...
suggest me a great geforce gt/gtx ddr3
rgnd
 Share
Can someone suggest me a great GeForce GT or GTX GPU (Graphics Card) which doesn't cost a lot? EXCEPT THE GT 730 (i have that already and its "broken") (make sure it's DDR3). kthnx
I think before anyone does that, you're gonna have to tell us why you want that. Because normally, that seems like a very strange thing to need. You'd likely get a better solution if you're more open to other things. Why do you want a GeForce card, and specifically one that uses DDR3?
Just so you know, the type of memory a GPU uses is completely independent of what your system uses. I can have a RTX 2080ti using GDDR6, and it'll work in a PC which has DDR2, DDR3, or DDR4
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
Why does it have to be DDR3?
Sincerely,
me
I don't see why you ONLY want a DDR3 card. How about a used 660 Ti? A used 970?
What's your budget?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
GT 1030 DDR4, take it or leave it.
/S
Usually a GTX 750 is a great budget card so consider something like that. A GT 730 is fine, but best only if you truly need a graphics adapter where there is none. I hope you're not buying new, because the used price of those cards is way too high.
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
First off, "great" "GeForce" and "DDR3" don't belong anywhere near each other.
Secondly, nobody is going to be able to help you very well it all if you can't even be bothered to give a finite budget. For all anyone here knows your budget could be 350 bucks, or it could be 5.
Main rig on profile
Zephyrus - Windows 7 side rig
AMD Phenom II X6 1055T (undervolted to 1.26v w/ CM 212 EVO), 1x8GB ADATA XPG V1.0 (1600MHz CL9), Asus M4A77TD, 240GB Kingston UV400, 1TB Toshiba 2.5", EVGA GTX 960 SC, Enthoo Pro, Corsair CX750M, Windows 7 Ultimate 64-bit
Mac Mini (Late 2014)
Intel Core i5 4278U, 8GB RAM, 250GB Samsung 840 EVO, macOS Monterey, using it with a ViewSonic VX2748
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X 1TB, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 2TB
Those low end DDR3 cards often perform worse than the integrated GPU of an Intel CPU. So unless you really need one for a Core 2, a HEDT or a server, it might be a better move to just use the iGPU or switch to a CPU that has one (like i3-8100 or R3-2200G)
Workstation 1: Core i7-9700K ~ 2x Corsair Vengeance LPX 16GB DDR4-3000 ~ Gigabyte Z390 UD ~ Sapphire RX 580 8GB ~ WD Black NVMe 1TB ~ WD Black 2TB ~ macOS Big Sur amd64
Workstation 2: 2x Xeon E5-2696v2 ~ 8x Kingston KVR 16GB DDR3-1600 Registered ECC ~ Asus Z9PE-D16 ~ 2x Reference RX 480 8GB ~ WD Black NVMe 1TB ~ WD Green SATA 6TB ~ Windows 10 Pro Workstation amd64
Home server: Xeon E3-1231v3 ~ 2x Samsung 8GB DDR3-1600 Unbuffered ECC ~ Asus P9D-M ~ Broadcom MegaRAID 9271-8iCC ~ Gigabyte 480GB SATA SSD ~ 8x Mixed HDD 2TB ~ 16x Mixed HDD 3TB ~ Proxmox VE amd64
Laptop 1: Dell Latitude 3500 ~ Core i7-8565U ~ NVS 130 ~ 2x Samsung 16GB DDR4-2400 SO-DIMM ~ Samsung 960 Pro 512GB ~ Samsung 850 Evo 1TB ~ Windows 10 Education amd64
Laptop 2: Apple MacBookPro9.2 ~ Core i5-3210M ~ 2x Samsung 8GB DDR3L-1600 SO-DIMM ~ Intel SSD 520 Series 480GB ~ macOS Catalina amd64
14 minutes ago, campy said:
Quadro FX 5600
Which is not great... So...
Main rig on profile
 Share
