Running GTX 750Ti with SATA
Solved by Mira Yurizaki,
14 minutes ago, Overlandr said:Hello, I am looking to update an Optiplex 3020 (i5 model) with a GTX 750Ti which I have already purchased. The card only runs at 60W stock, so if I plug a SATA to PCI-E power adaptor into the card will it pull more power through the cable or through the PCI-E slot which seems to have a max power output of 75W. This is because I am worried about the power drawn through the SATA power cable may be too much for it if more power is pulled from the cable than the slot.
Thanks.
Video cards that use additional power will likely be designed with different parts of the card drawing power from the slot or the cables to avoid power load issues.
