So, friends, im having problems regarding a noisy GPU fan.
See, i have a Diamond HD5670, a pretty old card which fan most of the time when booting my system, it starts spinning very slowly, making a pretty loud rattling noise, therefore, making its temps start rising really fast. And that leads me to shutting it down forcedly.
The big deal is, that it does not have a hole to see the bearings of the fan, as you can see in the images (that labeling is printed on the surface in the first photo). I dont want to force it, i dont want to break it and be without a dedicated gpu (despite being old, it holds like a champ).
So, what do you suggest me, what can i do to dismantle the blower without breaking it? Im not looking forward to buy an aftermarket cooling solution just yet (not enough funds).
The good part is, the blower is just a 2-cable fan, so i could easily replace it with a 80mm case fan and strap it with zipties, but i wanna see if i can do something first for the stock blower.
Thanks for your time guys :)
https://linustechtips.com/topic/993595-noisy-fan-need-help/
Try spritzing some WD-40 into the base of the fan and spin it with your hand a bit. Try to work something in there since it won't be watertight.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/993595-noisy-fan-need-help/#findComment-11954008
WD40 is not a lubricant and will only work for a few weeks before it will start to clog up everything.
https://linustechtips.com/topic/993595-noisy-fan-need-help/#findComment-11954024
I'm not recommending it as a lubricant
Primary PC:
PSU tier list
https://linustechtips.com/topic/993595-noisy-fan-need-help/#findComment-11954045
