Mechanical Hard Drive [ Overclock ]
Go to solution Solved by dj_ripcord,
Uhm... What? No that's not really a thing...
Want more performance? Move to an SSD.
There's not even a 'clock' in it, so you can't overclock a hard drive
Desktop benching:
21 minutes ago, SkieHacker said:
Does anyone know How to Overclock HDD ( Mechanical Hard Disk )?
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
if you take a car battery and adapt the sata power connector, It'll go fast.
you can run it in raid
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
Buy an SSD.
Theoretically, if you could spin the platters faster and make the head move more quickly, you could improve performance, but I know no practical way to do this, and if you tried it would almost certainly result in errors and/or destroy the drive.
I wonder if DriveSavers could do it. That would be interesting if they ever made content pieces.
If anyone could (successfully), I bet it would be them.  Well, or the actual manufacturer, but then you might cross the line from overclock to just a new model lol
Yeah, lol. They'd be loud though. I ran 15K SAS drives before 60GB SSDs were "reasonable" in like 2007 and oh man...
