Higher watte = less heat right?
Solved by X1XNobleX1X,
I was thinking since it uses less of the total output it's less hot...
That correct, though lets say you're using around 600watts. The heat on both the power supplies will be around the same.
Featured Topics
Purtrex ·
Posted in New Builds and Planning3 -
SnowyPatch24 ·
Posted in Phones and Tablets0 -
Mjball ·
Posted in Graphics Cards2 -
8
5
Bloodybluedragon ·
3
AlexGoesHigh ·
Posted in Linux, macOS and Everything Not-Windows3 -
