what's with my iPhone 7's battery drain at night?
Ashleyyyy
so when i go to sleep i usually put my iPhone 7 on my nightstand playing back music at low volume through the phone's speakers. i use spotify to play the music.
now here's the issue. the battery drains super quick while it's doing that. i've slept for about 3 hours last night (i know it's bad) and when i went to sleep it had about 40%. when i woke up it had 6%. what's with that?
She/Her
Open the battery app inside Settings & check what was using the battery in the last 24hours.   Funny enough, on my Moto G5S+ the Bluetooth is the biggest battery drain on a typical day for me - Even when I don't have my headset connected!
The wifi radio is also a culprit, though it should be minimal while streaming music. Not like streaming mp3's needs much data...
I don't use spotify, so does it do any kind of notifications between songs that might be waking up the device & turning on the screen?
spotify used 75% of the battery the last 24 hours. even though on a normal day i only use it for a few hours, and i use it while i sleep.
not that i'm aware of. at least not for me.
She/Her
Ouch!  Even a couple hours of YT on my Moto won't do that. I'd try uninstall it & clear any trace of it, them maybe try again. If you can, maybe check it's permissions & try to limit what the app can do.    Otherwise think you might have to keep it plugged in while listening.
7 is a new enough model I doubt your battery is the issue, so it must be something within the app going wonky.
i've got more than 3000 songs downloaded, i don't want to download it all again :(
ok i'll do that once it's done updating. it's currently updating to iOS 12 so maybe that will help too.
yeah maybe...
yeah i guess. settings says that my battery can handle the peak performance thing still so...
She/Her
iOS 12 has been absolutely amazing on my iPhone 5s
Quote or Tag people so they know that you've replied.
did it also improve battery life? i've been really happy with the performance on iOS 11 anyway. the only bad thing about the phone is the battery life for me...
She/Her
Just now, schwellmo92 said:
Sounds about right, the device can't enter any sleep states if you're playing music.
even in low power mode? forgot to mention i had that on too.
She/Her
Yes I would think so. I'll do a test with my iPhone X tonight and let you know what my results are.
Can you tell me, are you streaming the music? And are you connected to WiFi or on 4G/3G?
yes it also improved battery life for me, sorry for the late reply :) you're probably already on iOS 12
it's not so much as it improved the longevity, but it was ALOT more consistent
interesting. i'll see if it helps then.
She/Her
i'm connected to wifi. the music is stored locally (just the download feature in spotify) and i don't have any other apps open. i also have my alarm set but that shouldn't matter.
when it's playing the volume is at around 5 dots, playing through the speakers of the phone.
She/Her
TBF I am not sure its suppose to be playing music all night... O3O
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9(7) 5900X(ECO mode), 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A2 & B2: DDR4-3600MHz CL16-18-8-19-37-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.5GHz 10.54 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1, A2, B1 & B2: DDR4-2666MHz CL13-15-15-15-35-1T "Samsung 8Gbit C-Die" (4x8GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
Doesn't seem anyone in the comments thought about so I think I might be able to help.
I also have an iPhone 7. I have the same problem, charge my phone to 100%, go to sleep, then when I woke up, its about 20~30%.
Tried to search for fix, but nothing.
Turns out my phone is listening for siri command. Try to turn off your "Listen for Hey Siri" in your Settings -> Siri & Search -> Listento "Hey Siri"...
That fixed it for me...
CPU: Intel Core i5 3570K ( raped to 4.4Ghz) | Motherboard: Gigabyte GA-Z77X-UD3H | RAM: Corsair Vengeance 8GB | GPU: ASUS GTX 980 Strix
Case: Fractal Design DefineR3Storage: 256GB Crucial MX100 & 1TB Samsung Whatevs | Display(s): ASUS MG279Q1x Cheap LG Shit
PSU: Corsair HX650 or something | Cooling: Corsair H80i | Keyboard: Ducky Shine 3 | Mouse: Roccat Kone Pure | Sound: SoundBlaster Recon3D PCI-e
I play white noise with my iPhone 7 Plus while I sleep. I plug into some speakers. I always put it on airplane mode + low power mode.
why?
i have siri off... so that won't help me...
i haven't tried airplane mode. i'll try that.
She/Her
Be sure to update to iOS 12, check the battery usage tab, if Spotify is the one taking up all that usage then there is a bug with the app that the devs need to know about.
Could also be as simple as reinstalling the app. Especially if its been installed on the phone for a long period of time.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
i have updated to iOS 12. immediately a heart attack moment. i restarted my phone this morning and my touchscreen didn't work. after 5 mins of restarting it started working...
but anyway, i'll try to reinstall the app. kinda annoying that i'll have to redownload about 4500 songs using the app afterwards but oh well.
She/Her
Just the way it is.
1 minute ago, DrMacintosh said:
Just the way it is.
i know. it's just annoying.
She/Her
Jesus man, you have 4500 songs and you're relying on an app to store them? That's a fine example of why you should be using a PC to manage your phone. I keep my entire music collection (about the same size as yours) stored as files on several different HDDs, on site and off site.
spotify is a streaming service. the songs are only downloaded so that if i want to listen to music if i'm offline i can. this is a feature in the spotify app.
if my phone dies and all music on it is gone i can just get a new phone, log in to spotify and redownload them all.
it's a similar feature to netflix where on mobile devices you can download (some, not all) films and series to your device.
She/Her
