cooling suggestions
Hi guys, so recently my brother's cpu has began to hit 95c and I'm going to surprise him with a case and cooler. My question is, what cooler should I get him?
He currently owns an i5 4590 paired with a 1060 gb. I don't believe he has Oc'd or even touched that area for the gpu.
The case I will be getting him is more than likely a NZXT H500. It has better airflow than his current - diypc gamermax-w
He's been using the stock intel cooler and so it's just time for him to have cooler temps.
I don't want to go too overboard on his cooling since I just recently finished purchasing everything for my own build.  The budget I want to stick to is around $75 usd. I'd get him a cheaper AIO liquid cooler from like EVGA or Corsair but I don't think he "needs" it so air cooling should be fine.
Thanks for the help guys.
https://linustechtips.com/topic/974438-cooling-suggestions/
AIO's are overkill. A Cheap Air tower like the Cryorig H7, Arctic Freezer Esports or something similar will easily do the job.
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11776853
2 minutes ago, Derrk said:
noctua nh-d14 is exactly $75
maybe grab a d15 if you can find a sale.
i wish noctua would use better colors for their fans but you or he can swap them afterwards if he wants different colors
Those are absolutely pointless for a locked Haswell i5 unless the OP's brother has enough airflow around them to run completely passively... OP should just get him something like the H7 or AC 33 Esports or be hella basic and pick up a 212 Evo since they're all plenty quiet and will keep it frosty.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11776865
womp
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11776875
Hmm, I'll look into them, I do hear Noctua getting good reviews often.
I would LOVE to be hella basic, but his birthday is coming up, so a little style for the extra cost couldn't hurt. Plus I'm getting him a new case as well. The H500 will have decent airflow and a nice side glass panel to see the guts
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11776876
Yeah, ya gotta spoil the dude if it's his birthday. Personally I'm a bit salty the H7 wasn't a thing when I got my 212 Evo because I like it so much more.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11776929
For sure, going to get him this one xD https://pcpartpicker.com/product/bHcMnQ/cryorig-h7-quad-lumi-490-cfm-cpu-cooler-h7-quad-lumi
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11776995
My favorite cooler is the MasterLiquid Lite 120 AIO - usually find em on sale for $30-$40.  Cant hear it either.  I haven't overclocked on it but I don't plan on it (that's what the Corsair H100i V2 GTX is for) and going forward I will only be buying that price range AIO for any builds I do.  Convenient, cheap, and better than woosh woosh cause you can say you "Liquid Kewl!"
Give him the Liquid Kewl!
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11777085
The NH-U9S or NH-U12S would be more reasonable for that CPU.
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11777689
I do like the reviews for Noctua but those damn BROWN fans!!! They're hideous! They probably don't match anyones build unless they have a chocolate build going on lol.
I don't want to go and have to buy extra fans simply because the stock ones are too ugly :/
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11777799
An Arctic Freezer 33 eSports ONE would be a worthy cooling upgrade
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11778062
On 9/21/2018 at 9:22 AM, DVA said:
That's a bit overkill but works fine if he digs the look.
Cheaper alternatives include
M9i: https://pcpartpicker.com/product/LPVBD3/cryorig-cpu-cooler-m9i
Gammaxx GT: https://pcpartpicker.com/product/WDPzK8/deepcool-gammaxx-gt-295-cfm-cpu-cooler-gammaxx-gt
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11780753
Can't decide between the one I picked earlier, or this one. I know he doesn't need it, but hey it looks nice and it'll keep everything cool
https://www.amazon.com/gp/product/B071F5VXJ3/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11780827
Go with air cooling. It'll be cheaper, quieter, more reliable, and easier to install.
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11780852
check out the ice blade 200MM by deepcool, keep in mind its quite tall, if you need anything shorter and nicer looking a thermaltake c7 would be my choice. If you want a big performer like the deepcool cooler but in a better looking yet more trusted brand, get the H7. If you want an AIO, my recommendation is the masterliquid 240 lite, its like 60$ for an aio thats 240ml. If you want RGB in your life get the 65$ Master liquid 240 lite rgb, has everything the non rgb aio has but with rgb.
https://linustechtips.com/topic/974438-cooling-suggestions/#findComment-11782593
