Using good DAC for Monitor Built-in Speakers
_Hustler_One_
I have a monitor which has built-in speakers on it.
I'm wondering to use a good DAC to make better sound although it's a built-in speakers. Is it worth it or just a waste?
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
Does the audio run over the monitor cable or an analog input?
If its the former there is nothing you can do, the DAC is built-in to the monitor.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Honestly getting some separate speakers and using that instead of buying a DAC will most certainly produce a way better sound
R5 3600x | RTX 3070 | 16Gb 3200mhz | Gigabyte B550 gaming x | 500gb 660p SSD + 1tb wd blue HDD |
I'm using Display Port cable from VGA card to monitor, so the audio will be there also.. If the DAC is worth it, how to connect it to my monitor without conflict with the DP?
My system specs:
My build logs:
This answer is reffering to "it's just a waste"..
Thanks for the inputs..
My system specs:
My build logs:
You can't.
Also, if you could, it would not be worth it.
9 hours ago, spwath said:
You can't.
Simple and direct. I love it.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
