hey im going to upgrade my AMD fx8350 and my
ASUS Crosshair V Formula-Z  to a Intel 4770k and ASUS MAXIMUS VI HERO
but is it the right way to go?
i would like a motherboard with more Red details is there any with the socket 1150?
Cpu: intel i7 4790k    Motherboard: MSI GAMING 5   GPU:Nvidia GTX 980Ti   PSU: Corsair AX 760 PSU  RAM:Crucial DDR3 Ballistix Tactical 24GB RG  SSD: OZC Vertex 4 128GB  HDD: 2x1tb WD  Case: Thermaltake Level 10GT Snow edition!
https://linustechtips.com/topic/96353-hey-i-need-some-help-deciding/
why would you do that instead of getting a new video card for that money?
Edit: but to your question: the Maximus 6 extreme has some more red...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Why are you upgrading?
i got a asus GTX 680 direct cu 2 top 2gb and i dont wanna upgrade to 780
but that would give you significantly more value (gaming performance) than getting a new cpu.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Plays MMO/RTS or uses Dolphin emulator? Would be the only reason I would upgrade. AMD gets half the FPS in some of those games. :(
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
I'll take your mobo when you switch. I could use a spare. lol
I agree with @FloRolf if you're coming from an 8350 really the only way up is to go 2011 and six core Intels, 3930K/4930K.
Otherwise it won't be a worthwhile upgrade.
What games do you play by the way ?
another reason for upgrading is cuz i wanted the intel upgrade for a long time aswell as im building a secound The Gathering for lanpartys and shit and then i can have a beast of a main and a decent secound running the cpu and motherboard and a gtx 560ti
Well if you play MMO's? Intel is ahead by quite a bit due to FPU speed. The z87? The cheapest Asus/Gigabyte/MSI will = the most expensive as long as it has SLI (if you need it) in performance/overclocking. You are basically paying for looks. I think the gd-65 from MSI has a nice red/black scheme but some hate it due to brown PCB. It is all basically paying for looks past a sli board from a decent vendor.
Pick the one you like the most (looks) and that is in your budget, with how much looks matter in that budget. You can't go wrong with any of those brands or any of the sized boards for that matter. A mini-itx z87 = ROG board as far as performance. For lan parties something like a Bit phoenix and any of those 3 brand z87 would be pretty cool. You can go smaller then Prodigy, but the cases can get pretty tight to work in.
You could also just sli 680's.
I'd make a smaller secondary system for that. I'm not sure why you'd want to lug an atx build with a 8350 to a lan part.
The Gathering is a 7 days lanparty in norway and i plan to sell it at the end of the week then build a matx build in a bitfenix prodegy m :)
this you meen ? http://www.komplett.no/msi-z87-gd65-gaming-socket-1150/782191 sorry norwegian page but it got pictures xD it looks like it got black pcb
Why not keep your current system as your main rig?
I personally wouldn't recommend a 4770k if you have an 8350. Why would you drop all the cash for a total platform change if you have a pretty decent cpu already? That and games are going to start taking advantage of it's 8 core functionality. Pick up an AIO cooler and overclock it some :)
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
I tried looking for a good board, for 1150, that is sexy blue. Found NONE from Asus, and even Gigabyte have some black and blue ones, but it is lower end and not worth it.
To love is to risk not being loved in return. To hope is to risk pain. To try is to risk failure, but risk must be taken because the greatest hazard in life is to risk nothing.
i got a h70 but when i play cod my game is fucked up i cant max the settings and my cpu is at like 65 degrees
Woah bud something isn't right there. A 680 not maxing cod is absurd, is your 8350 overclocked? My stock cooler does 4.4Ghz and I don't get above 60 using stress tests.
im not sure i know a lot about parts but nothing about cooling xD
thank you all for replaying im going to do as you said im buying a GTX 780ti!
So....can I still have your Crosshair V Formula-Z? :P
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
funny it costs more to send it to you then buying a new motherboard xD
