So I have been wondering, is getting a UPS worth it?
I never used one, and the last PC I had before my current rig actually died during a big and long thunderstorm that happened to shock some big transformator nearby to where I lived at that time.
Generally in my area we get power outage few times a year (like 3 to 9 per year I guess) and I do use surge protected extending cable.
I do not work with any really important data, I do not run any VM server or anything like that. What I may lose data wise, is probably at the most some play time after last save.
However I am sure, that not getting unexpectedly shut down by power outage is a good thing for any electronics. But is it worth the money?
And if it is worth the money, especially with the rig being like 2000 euros, what should I look for when searching for PSU?
CPU: Ryzen 7800X3D; CPU Cooler: Noctua U12A chromax + NA-HC8 chromax; MOBO: Gigabyte B850M Aorus Elite Wifi6e; CASE: A3-Matx Lian Li Dan Case Wood/Mesh edition; PSU: SF1000 (2024); RAM: 2x16 GB DDR5 Kingston Fury Beast 6000/30cl Expo kit; SSD#1: 1 TB 9100 PRO; SSD#2: 2TB 990 PRO; GPU: RTX 5080 Asus x Noctua; Case fans: 1x A12x25 G1, 2x A14x25 G2 chromax; OS: Win 11 Pro
https://linustechtips.com/topic/946041-ups/
If you don't need a UPS, you could just get a surge-protector -- it'll protect you against thunderstorms just as well, it just doesn't have a battery in it.
EDIT: Didn't notice you mentioned that you have a surge-protected cable. Must be pretty shitty, though, if it didn't actually protect your previous rig.
https://linustechtips.com/topic/946041-ups/#findComment-11518578
My server has its own PSU. But this server also contains (among others) a virtual NAS that - for obvious reasons - shouldn't lose power all that suddenly.
In those cases I would highly suggest having a PSU. Otherwise a surge protecter is a perfectly fine.
https://linustechtips.com/topic/946041-ups/#findComment-11518612
Did not have one seven years ago, that is why it did not obviously protect the pc before.
https://linustechtips.com/topic/946041-ups/#findComment-11518613
The thing I like most about my UPS devices is that during a power cut you can select it to tell the PC to enter hibernation after a set time.. this is pretty useful for me, as when the cut is over you can then power the system back up and everything is running how it was before, so no having to go around re-starting things and such.
I have one of my UPS just for my router/switches, so if the power cut isn't affecting the telephone exchange or roadside boxes, then I can still use my phone and internet.. on my UPS I get around 120+ mins, so at least I would have some entertainment and communications without resorting to my shitty 4g signal and hotspot any more :D
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/946041-ups/#findComment-11518701
Oh, just to clarify, that time is ONLY for the router and such. The PC UPS system also has my miner into it at the moment... and I get a maximum of 3 mins at full power :D
That will change soon as I will purchase another one just for the miner, though TBH I have it set to power both the miner and PC down after 1 min to be safe ATM.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/946041-ups/#findComment-11518713
Surge protectors arent really good enough when it comes to a PC. They will allow plenty of under and over Voltages through.
I havent used a computer without a UPS in almost 20 years. 5-10% of the price of the computer for the protection a good UPS offers is a no brainer.
One unexpected shutdown during an update can mean spending hours reinstalling everything too.
https://linustechtips.com/topic/946041-ups/#findComment-11521488
Undervoltage doesn't break a computer, overvoltage can, but a UPS isn't any different from a surge-protector when it comes to protecting against overvoltage.
https://linustechtips.com/topic/946041-ups/#findComment-11521494
Undervoltage can definitely damage hardware. Heres a few threads and discussions on it with examples.
https://electronics.stackexchange.com/questions/65824/can-electronics-be-damaged-by-undervolting-it
https://ustpower.com/comparing-automatic-voltage-regulation-technologies/need/avr-guide-voltage-high-low/
https://superuser.com/questions/113113/why-are-brownouts-so-harmful
Any decent UPS will have AVR with configurable Voltages at which it will switch to battery power for both over and under Voltage conditions, in addition to some fast acting MOV based surge protection and noise filtering.
https://linustechtips.com/topic/946041-ups/#findComment-11521529
just a FYI: those do absolutely nothing. all the protection they have is already built into your power supply.
on topic:
i have a UPS, or more specificly i have 3 (soon to be 4). however, i'm not convinced everyone should have them. for me its mostly a matter of sometimes i'm dealing with stuff that'll be a lot of work to get right if i get an outage in the middle of this, and i'm in a *very* unfortunate power grid situation due to a combination of many reasons.
i currently have a small UPS for my router and modem, a bigger one for my home server and its peripheral devices, and a beefy one for my main pc. the combination of these allows me to bridge at least about 30 minutes, in most cases even allowing me to finish what i'm doing and shutting down everything safely. the downside to this is that the total cost of the 3 devices is probably close to the €1000 range, and while lead-acid batteries arent excessively pricy, replacing them when they fail does count into the bill too, as well as the UPSes also consuming some power, which actually counts up to a noteworthy amount.
all in all, if you get a UPS, buy nice or buy twice, and take good consideration if it's even worth it.
https://linustechtips.com/topic/946041-ups/#findComment-11521604
