NAS Build for Small Office
1 hour ago, Stylin80 said:Well, blaming it on firmware update requirement is another way to escape .
As for building it, well I'm interested and may be willing to give it a go, but it's true, responsibility will be falling on my shoulder, but I will be more than willing should I build it.
As for buying, i've actually been getting multiple suggestions to buy as well. Is this a suitable choice? Been eyeing on it as well.
Qnap TS-453a
Well in terms of budgeting I am looking somewhere within 2K USD.
I would also suggest buying, not building.
Why? Service warranties, and uptime.
If you just slap together a tower - even with new parts - and something dies, what are you going to do now? Wait the 1-3 weeks RMA time while your ENTIRE office is down and unable to access the files?
I have some important questions:
1. The 10TB you mentioned, is that your current need, or is that a projected need? How much "free space" will 10TB give you, as of right now?
2. What is your current backup strategy?
3. What is your planned backup strategy with the new NAS?
I would suggest buy 2 NAS's, one as your primary NAS, and another as your backup target. Configure the primary NAS to create scheduled, frequent, differential snapshot based backups and store them on the 2nd NAS.
Make sure to configure extra storage capacity on the 2nd NAS, since it has to accommodate your current files, plus file versioning (Eg, you create a CAD file. You edit it. A few days later, you edit it again. Now there's at least 2 versions of this file to backup).
Possible specs:
QNAP BUILD
Primary NAS:
1x TS-453A (4GB RAM version - there's an 8GB RAM version, but I don't think you need it) - $800 USD
https://www.newegg.com/Product/Product.aspx?Item=9SIAFMC73H4597&cm_re=TS-453A-_-22-107-279-_-Product
4x Seagate Ironwolf NAS drives - $125 USD each ($500)
https://www.newegg.com/Product/Product.aspx?Item=N82E16822179005&ignorebbr=1
You could buy WD Red NAS drives as well - they are comparable and within $5 price
This gives you 4x 4TB = 16TB of raw storage. Run the system in RAID5, which will reduce usable storage by one disk = 12TB of actual space. If you don't need 12TB, you can swap the 4TB drives out for 3TB drives, and get 9TB of actual space.
Primary NAS total cost: $1300 USD + applicable taxes and shipping
Secondary NAS:
1x TS-253A (4GB RAM version) - $465 USD
https://www.newegg.com/Product/Product.aspx?Item=9SIA6ZP3RB4799&cm_re=TS-253A-_-22-107-281-_-Product
2x 12TB Seagate Ironwolf NAS drives - $410 USD each ($820)
https://www.newegg.com/Product/Product.aspx?Item=N82E16822172025&ignorebbr=1
This gives you 2x 12TB = 24TB of raw storage. Run the system in RAID1 (mirrors the drives), which will give you 12TB of actual space to work with. If you opted to go with 3TB drives in the Primary NAS, you can swap these 12TB drives for 10TB drives, and save around $200 from the build.
Secondary NAS total cost: $1285 USD + applicable taxes and shipping
Total QNAP NAS build: $2585 USD + taxes and shipping
You can play with these configurations a bit. For example, you could get 2x of the exact same NAS's and HDD configurations, which will give you a bit more future flexibility (I think it's worth the extra $15, perhaps).
You could also scale down your storage needs to save money, such as going with smaller drives, and less total storage.
You could also swap out the QNAP for a Synology, for example. The DS418 (non-Play) is about $400 cheaper, but has less powerful hardware. The DS918 is still pretty powerful and is $200 cheaper.
Synology Build:
Primary NAS:
DS918+ - $550 USD
https://www.newegg.com/Product/Product.aspx?Item=N82E16822108682&cm_re=DS918-_-22-108-682-_-Product
Primary NAS total cost: $1050
Secondary NAS:
DS918+ - $550 USD
Secondary NAS total cost: $1050
Total Synology Build: $2100 USD + taxes and shipping
So the Synology build ends up being ~$400 cheaper. You could, again, save cost by buying smaller HDD's, but you get diminishing cost savings at this point.
I also opted for both Primary and Secondary to be identical, since you save very little money going with the 2-bay Synology vs the 4-bay, and the increased cost of HDD's for 10 or 12TB HDD's was simply not worth it. The 2-bay Synology would end up being $200 more expensive than the 4-bay, when including HDD prices.
Configuration:
Setup the Primary NAS as your SMB Share or shares.
Configure in RAID5.
Create as many shares as needed.
Create basic user permissions (Eg: if only the accountant needs access to the accounting folder or share, do so). If you have an AD network, you can integrate AD users, but not required.
Setup the Secondary NAS with with RAID5 as well.
Install backup server on the Secondary NAS, and backup client on the primary NAS (Synology and QNAP both have similar software to do this - I use Hyper Backup from Synology for our Archive NAS at work).
Create your backup schedule - I might suggest every hour or every 2 hours. Target the Secondary NAS as the backup server, and it will automatically sync backups over to the secondary NAS on a regular basis.
You can configure how long you keep a backup (Eg: Files over x years old can be deleted), or you can just keep filling it up as needed with no retention policy.
If you need to upgrade your storage?
1. Buy new matching disks for the primary NAS.
2. Save the current config.
3. Remove the existing array.
4. Replace the disks.
5. Create new larger array, reload the config if necessary.
6. Reload your data from the secondary NAS backup
Repeat the process on the secondary NAS, replacing all disks, creating new array, then perform a fresh backup.
Alternatively, if you wanted to keep all the old file versions, etc, you could temporarily mirror the secondary NAS to the primary to hold all backups (including old data). Takes a bit more planning, but could be important for some people.
Let me know if you have specific questions.
