bottom of cooler possibly uneven, temps rising over time
CChernobyl
I have a 6700k and a noctua nh d15s and the bottom of it seems uneven i put a flat lego brick on the bottom and i could rock it back and fourth also after i apply thermal paste and run prime95 max heat my temp maxes out ~70c but if i wait 3 days after applying and run it again it goes over 90c. Can i fix this somehow or do i need to buy a new cooler?
What paste is that?
It's fine for the base plate to be slightly curved, that's why you put thermal paste. I guess you havent used enough paste and didnt tighten the spring loaded screws enough
Desktop benching:
It's normal for heatsink bases to be convex for better mounting pressure. Make sure that the cooler is evenly mounted and that you're gradually tightening the screws instead of one side before the other.
9 minutes ago, Jurrunio said:
What paste is that?
I have tried thermal grizlly, n1 h1, and gelid extreme and im getting same results and ive reapplied everything atleast 20 times now
What are your specs and how is your airflow laid out? What motherboard settings are you using?
Did you tighten the screws gradually as opposed to one side before the other?
Noctua does test each heatsink. But there's still human error involved. Contact their support.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
