I got a ryzen 5 5600 rtx 2080 ventis
x570 elite 16gb. What’s graphic settings and fps should I expect
/ my warzone runs on all low settings hits 140-160 fps
but then I put everything on extreme settings everything on at highest settings I her 100-120 fps
is this meant to be like that ^
fortnite I think same case can lower th graphics all the way gain little more fps but I can higher my quality and it not hinder the fps too much
fornite alot better tho running stabs 165 as pc is only 165 and med-high settings
https://linustechtips.com/topic/1571879-i-need-help-please/
CoD just runs like dogwater, not much you can do about it. I could run many demanding games at max graphics but warzone I had to drop settings and rely on FSR.
Lack of framerate increase suggests that your PC has a CPU bottleneck isssue.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1571879-i-need-help-please/#findComment-16423221
roughly yes.
its an a bit older midrange system so you can expect midrange performance in most games... recommend lowest settings as a baseline and go from there with what you're comfortable.
don't get me wrong, its not a bad system at all... its just a bit of an odd question,  every game is different and you'll never get the performance you would get with a new'ish higher end system,  thats just a fact.
but as said these numbers seem to be about right.
-Scott Manley, 2021
https://linustechtips.com/topic/1571879-i-need-help-please/#findComment-16423902
8 hours ago, Mark Kaine said:
160fps is dogwater?
For an FPS game that's the bare minimum and it's worse here by the brutal upscaling severely impacting the picture quality making it harder to spot enemies in the distance. If it was  100% native resolution at 160fps it would be better, still not great, especially when considering that other esport fps games push well beyond 144fps, Fortnite, CS, Valorant, Siege, Apex, Titanfall 2, Battlefield and so on.
https://linustechtips.com/topic/1571879-i-need-help-please/#findComment-16424160
