Cant use my SD Card for my phone
Go to solution Solved by Donut417,
17 hours ago, pcguy0000 said:
I tried but it will only let me format as portable and not internal
On the Manufactures page, at the SD card specs it says for storing multimedia files. Your probably only going to be able to make it portable storage. Not every phone allows you to make SD act like internal storage. As not every phone on Android supports SD cards because SD cards are not supported by stock Android, its a feature that is added in by manufactures, how they add it is up to them.
So I got a phone recently, but I cant use my 128gb sd card i put in. i dont understand how i am meant to store my stuff there....
I am using a bq aquaris x and a 128 gb sandisk sd card.
9 minutes ago, pcguy0000 said:
Yes. I meant micro SD.
Apparently, the phone only uses the SIM 2 slot for that.
Also, have you formatted the card?
Because that's what SD cards are, portable storage. Internal storage is what is built into the phone, not what you add afterwards.
Scrap that. Is the card a UHS-1 rated card?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
