arctic freezer iii fans replacement?
Solved by RevGAM,
45 minutes ago, thenoor said:hello i have a arctic freezer iii 280mm my question is can i replace the raddiator fans with another like 140mm slim fans from arctic?
Of course. The higher the static pressure is, the greater the improvement. Do not get fans that have a similar static pressure! The current fans only have 2.4mmAq pressure, and trying slim fans is going to be very difficult because they just can't provide much pressure without a proper blade design and really high RPM. Those Arctic slim 140s only have 1.55 mmAq, which is not good.
You should look for the strongest fans you can find, and absolutely no less than 3mmAq of pressure, IMHO, if you really want better performance.
