3 minutes ago, loopie said:
Hi guys,
Been told that even a Hyper 212 is enough, so I guess my next question is if I want it to look nice, which model do you suggest?
any of the NZXT Kraken models look really nice in my opinion
https://linustechtips.com/topic/931618-best-looking-air-cooler/#findComment-11386743
Depends what you think that looks nice?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/931618-best-looking-air-cooler/#findComment-11386766
19 minutes ago, loopie said:
Hi guys,
Check the TDP of your CPU. Size a cooler that at least meets that number and that will fit the socket you have. Looking nice is all down to personal preference. I think the Be quiet! dark rock coolers look pretty good.  Mine might not be a popular opinion. But my favorite are Noctua coolers. They're easy to mount, come with a tube of good quality thermal grease, and have a good build quality for the price. Plus the brown fan reminds me of a silky smooth caramel...makes me hungry everytime I look at it.
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
https://linustechtips.com/topic/931618-best-looking-air-cooler/#findComment-11386791
My personal favorite is Be Quiet Dark Rock Pro 4.
CPU: i7 6950X  |  Motherboard: Asus Rampage V ed. 10  |  RAM: 32 GB Corsair Dominator Platinum Special Edition 3200 MHz (CL14)  |  GPUs: 2x Asus GTX 1080ti SLI
Storage: Samsung 960 EVO 1 TB M.2 NVME  |  PSU: In Win SIV 1065W
Cooling: Custom LC 2 x 360mm EK Radiators | EK D5 Pump | EK 250 Reservoir | EK RVE10 Monoblock | EK GPU Blocks & Backplates | Alphacool Fittings & Connectors | Alphacool Glass Tubing
Case: In Win Tou 2.0  |  Display: Alienware AW3418DW  |  Sound: Woo Audio WA8 Eclipse + Focal Utopia Headphones
https://linustechtips.com/topic/931618-best-looking-air-cooler/#findComment-11386879
Well, looks are really subjective. Dark Rock coolers are among others, but there are more to my eye and definetly more funkier.
Phanteks PH-TC14CS, PH-TC12DX, PH-TC14PE
Thermaltake CL-P0508, CLP0554, CL-P0466, Frio OCK
Zalman CNPS9900NT, FX100, CNPS12X
Enermax ETS-T50 AXE
And ofc CoolerMaster MasterAir Maker (or whatever its called) and its predecessor V8 GTS.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/931618-best-looking-air-cooler/#findComment-11387044
It depends on what looks nice to you and what cpu you're cooling.
What are your specs? Where are you shopping / located? What kind of aesthetic are you aiming for?
https://linustechtips.com/topic/931618-best-looking-air-cooler/#findComment-11387703
