Which monitor for 1080p?
skeeler88
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
    Gskill 16gb 2400 RGB
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
    Samsung 850 evo 500gb
     WD black 4tb
     WD blue 1tb
     Kingston ssdnow v300 128gb
  • PSU
    Corsair HX750
  • Display(s)
    2x Asus - VG248QE 24" 144Hz 1080p
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
1 minute ago, speedbeastxx said:
I would get this one as well.
Asus for sure. Benq is only 60hz, Asus is 144hz.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
I liked it so much I bought a second one, very good for the price. The 3D features are useless in my opinion.
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
If i could get a BenQ 27in 1ms, 144hz, would that be the better option?
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
Just now, speedbeastxx said:
you will need to use DVI-D or Display Port to have 144hz.
um can you explain what that means?
HDMI on can do 60hz unlike DVI-D and display port which can do 144hz.
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
doesnt that benq I listed have a DVI-D
all monitors have dvi-d, what matters is the screens refresh rate. dvi-d can do any refresh rate up to 144hz in 1080p.
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
1 minute ago, sample text said:
you are comparing a 144 hz monitor with a 70hz one..which means you will play a 144 fps (if your GPU supports that) and the other one will have max 70 fps
check that link https://linustechtips.com/main/topic/729232-guide-to-display-cables-adapters-v2/
so is asus a better brand? what if I find a comparable benq monitor
im not saying asus is a better brand. just this asus monitor is better for gaming,because it has more hz which means you can play on more fps if your gpu is good enough.if you are lazy,go to 01:43 https://www.youtube.com/watch?v=yLT7-UiScLU
