1080p gaming 100+fps minimum with ULTRA settings
Kenjo
As title states..
Best GPU to MAX out all eye candy settings while gaming at 1080p , not interested in cards that dip below 100fps at ANY time not even MENU, Nor am i interested in a discussion about monitor refresh rates etc, Best possible GPU for 1080p ULTRA settings TRiple A titles / Esports / mid range titles...
System:
R7 2700x
X470 board
16gb ddr4@2666mhz
GTX 1080 Ti
Personal Desktop":
Luna, the temporary Desktop:
2 minutes ago, Princess Cadence said:
GTX 1070 Ti
Not powerful enough to run 1080p Ultra settings over 100 fps in alot of titles.... why suggest it ?
Lol without any budget limit go 1080 TI
If u rich AF, Titan V
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
Im stuck between the Msi 1080 and msi 1080 Ti its a difference of 200 usd.... and my bro is showing up tomorrow so i kinda need to decide in like 14h what to choose hate the stress ;) (yes he is funding abit ;)
9 minutes ago, Kenjo said:
A titan V under Ln2
The GTX 1070ti makes more sense than a 1080 if the price is a lot lower .
1070 Ti and 1080 are the same thing, you need the 1080 Ti
Personal Desktop":
Just now, Streetguru said:
A titan V under Ln2
haha why not just send the PC to space and run wifi ;) absolute 0 up there ;)
Look, it comes down to budget. If you want the best-of-the-best, then the 1080TI. If you aren't comfortable with the price gap, the 1080.
the 1080 has anywhere from a -5 to -20 FPS of the 1080 TI.
Since you're at 1080p, I'm sure the GTX 1080 will do you fine. If you for sure need the 100+ FPS, then the 1080 TI will secure that.
IDEK what game this is but it kind of helps
Yeah lets just hope my brother decides to give me some Pesetas tomorrow budget i have is 950 Usd and with the 1080 ti it ends up 1200 usd... so he BETTER dish me some cash ;)
Damn that an awful deal. Thought about used any???
UPDATE: 1070 Dual SLI might actually be a better deal, and can perform at or better than the level of a 1080 TI, though (as in the case of Hitman), not all games utilize SLI. Also, SLI is janky. Your choice.
Yeah you could buy the 1080 TI used lol
https://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=1080 ti&_dcat=27386&rt=nc&LH_ItemCondition=3000&_trksid=p2045573.m1684
4 hours ago, DaJakerBoss said:
Cant buy Used ;) hard for my brother to deducte the tax via his company ;) (vat)
oh forgot to tell you about the budget ;) 700 usd GPU / rest is x470 / 2700x  + Phanteks p400 Tempered glass ;)
52 minutes ago, Kenjo said:
As title states..
System:
R7 2700x
X470 board
16gb ddr4@2666mhz
There isn't a GPU that currently meets those requirements, not even the Titan V. I think you need to recalibrate your expectations.
If you're prepared to not "MAX out all eye candy settings", and aim for something a bit more sensible, then you'll be looking at a 1080 Ti.
Just now, Morgan Everett said:
Posting links without commentary isn't helpful: what am I supposed to be taking from it? Note that I've owned a 1070, 1080, and 1080 Ti, so am pretty conversant with the capabilities of all of them.
If you clicked the link you would see that the 1080 ti keeps over 100 fps in max settings... but your right i should have added that but i totally neglected that since im currently stressing about looking at sites for the best choice ;)
Yeah, those benchmarks aren't very useful, since there's almost no detail to them or explanation of their provenance. As I've said, I've owned the 1080 Ti, and read plenty of reviews (including detailed benchmarks) of it prior to purchase. It's not going to be good enough, much as the Titan V wouldn't be.
Yeah, those benchmarks aren't very useful, since there's almost no detail to them or proper explanation of their provenance. As I've said, I've owned the 1080 Ti, and read plenty of reviews (including detailed benchmarks) of it prior to purchase. It's not going to be good enough, much as the Titan V wouldn't be.
Kind to elaborate, aka what games and resolution 1080 / 1440 etc ;)
I'm not quite sure what you're asking for.
Basically ,  what Resolution did you play at on your 1080ti what games did you play and your MSAA/AA etc ;)
I think he‘s a troll
That's a pretty broad request. What are you trying to achieve here?
100 fps in fraps with a 60hz screen
sounds like that
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
