What program for monitoring cpu's is used by common tech yt-ers?
Solved by kirashi,
3 hours ago, lolimaster555 said:Theres some program that all tech-youtubers use to look up cpu-usage temperature and thermal throttling at the same time with graphs, but i cant find the name of it anywhere. does someone know what its called?
100% is AIDA64 if you're talking about the program that graphs thermal throttling during a stress test. HWMonitor and CPU-Z are 2 other good alternatives, along with Open Hardware Monitor.
