My (a little bit old) PC
Keltyx98
Hi!
I just entered here and I would like to share with you my build:
CPU:
Intel i7 - 4790k, OC 4.8GHz 1,398V
GPU:
Gigabyte GTX 970 Windforce 3x
Motherboard:
Asus ROG Maximus VII Ranger Z97
RAM:
2x 8GB HyperX Savage DDR3 1866MHz CL11
2x 4GB G.Skill Sniper DDR3 1866MHz
PSU:
Cooler Master GX750 bronze 750W
SSD:
256GB Intel
HDD:
2TB Seagate Barracuda
CPU Cooling:
Enermax Liqmax II 240
Case:
Thermaltake V3 Black Edition
Welcome ;)
Sharp looking system, thanks for the share :) there is no need to make a post for this specifically, though. This is best suited as a status update on your profile. We can see it there no problem.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
17 minutes ago, Keltyx98 said:
ah ok sorry, I cut-paste it in my profile
thanks!
it's ok, it can stay here. No need to have it deleted ;)
If you need help with your forum account, please use the Forum Support form !
