Am i running dual channel ?
Solved by faziten,
1) Swap RAM sticks with each other, sit them properly. (Being detected is not enough to say it's installed properly.)
2) check this: Win+R> msconfig > boot > advanced options > if "Maximum Memory" is unticked like this (don't mind the processor count).
It can be a RAM compatibility issue or a non working slot. Remember to check you motherboard manual to install the modules in the suggested order if you have more RAM slots than RAM sticks installed.
