Under 200$ Wired Headphones
On 2018-03-25 at 11:41 AM, FloRolf said:
The good stuff!
10 hours ago, Sabron said:Never used them but Phillips SHP 9500s are some of the most recommended open back headphones under $100.
I’ve gathered they might be a good option. I prefer the Sennheiser fitting (big oval felts over my elephant-ears). The head clamp has never bothered me & it can be quickly fixed with GENTLE bending.
13 hours ago, Tarun10 said:I looked at the recommendation from a few channels and Reddit posts and I have shortlisted these.
Status CB-1
Sennheiser HD 598 SE
ATH M40X
AKG K553
ATH AD700X/500X
Philips SHP 9500s
Which of these is the best value for money?
Also what is the difference between the 598 and 599???
Any reviews from owners of these headphones??
I’m a big big fan of the Sennheiser brand. The HD5## series cans I have are tough! The only issue I have with them is the excessively long cable (~2 metres?!). Unfortunately, I can’t discern the difference between the late model 599 (open versus closed cups?). What I do know is that the HD6$$ series were a significant jump in quality (based on me muddling around different forums & try-ons at expensive shops). I have a HD650 on order that I’m looking forward to (they’ll be powered by an external headphone amp for best results). The HD600-series are experiencing a price spike here in Ontario, so I’m ordering a clone sold by Massdrop in California (the HD6xx). Unfortunately, they’re only shipping them to North American addresses.
M40X ... ... ... ... ... Well... ... ... THAT model is very polarizing on this forum. I’m going to remain a polite Canadian, and say nothing more.
Your challenge will be to get product to you in SE Asia. I’m guessing you’ll get zapped with all kinds of import fees and “special shipping charges”. That’s BS.
My vote: a pair of Sennheiser cans. If you chose the HD600-series, you might get more satisfaction with a headphone amplifier (double check this, eh). I’m assuming their distribution is more reasonable to your neck of the woods.
BTW - according to a friend of a friend, CBC-Radio-99.1FM use AKG K271 in their studio. Helpful?
Cheers from Toronto (hey, it’s above freezing here! In the sun. At noon. As long as the wind’s not blowing).
