An Open Letter (and question) to Cooler Master N200 Owners
Solved by Evanair,
17 hours ago, DanielMDA said:you sure?
Yes, he's correct. the PSU connection is male and will only fit one way and plug. connect all 3 together and plug into the appropriate cable from your PSU.
Computer manufactures have come a long way to key and color code every connection so you can't plug in the wrong thing. It didn't use to be this way, but now a days as long as you don't force something and pay attention to plugs and keys, you'll be fine.
