Best air cooler for i5-8600k
1 minute ago, Geotropism said:From what you said, I gathered that the Noctua is better than the Mugen 5 so I went with it. I don't mind the noise level as long as it's not overly loud and unbearable- I play with noise cancelling headphones most of the time. With that in mind, do you still recommend the PW2's? I mainly went with the SP140 because of the white LED which I think would make my case look much sexier. Are static pressure fans good for front intakes if it's mesh?
They're both quiet coolers and you won't notice a difference if you're not aiming for a very quiet system. If you just want something that performs well, SP140's are fine. That being said, the same reasoning would make the Mugen 5 the better buy. PW2's and NF-P14S' both have the advantage of being quieter and having a longer warranty than the SP140's 2yrs at 3yrs and 6yrs respectively.
What's considered a static pressure oriented fan is arbitrary. All fans have some degree of both static pressure and airflow and you generally want as much airflow as possible while having enough static pressure to overcome any obstructions in the way. If you're asking for which would perform the best, from best to worst: NF-P14S, SP140, PW2
