How does the water in water coolants stay cool?
11 minutes ago, linus69 said:If a water cooler is meant to cool down parts with cold water, does the warm energy not move into the water stream and thus make the water warm? And if the water cools down, where would it cool down? In a corner?
-Confused linus69
The water flows through the radiator, fans blow air across the radiator, energy transfers from the water into the passing air because the air is lower temperature. Water cooling works no differently then air cooling, the only difference is that the heatsink is not in direct contact with the heat source because size and weight limits the maximum dimensions of the heatsink, instead we place the heatsink somewhere more convenient where it can be as big as we want, and use water to ferry the heat back and forth between the now-detached heatsink and heat source. The water doesn't do the actual cooling bit.
