Thing to mount cable on wall (Explains more)
Solved by W-L,
2 minutes ago, Saddy said:Hey, so I am in the need of routing a 50ft ethernet cable from my modem to my computer. I have found this cable, but I want to have it along the bottom of my wall, and I need something to hold it up there. Does anyone know of anything to stick it up there? I would prefer if it was able to come off.
The command clips are nice as their adhesive easily removes with no marks, but if you want something a little more clean you can get cable raceways to hide it.
