Is my repair tech correct?
4 hours ago, fear92 said:Much appreciated, even if it was an interesting discussion to follow I understand that it went a little overboard.
Thanks for the reassurance, I always thought that 750w might have been an oversized safety net.
The Arizonian guy is just completely wrong. I don't know what he was really trying to do.
The recommended from Nvidia comes from them wanted to cover their asses so you don't pair a 240W OEM HP unit made of wrapping paper and Tic-Tacs with a GTX 1080. A 1080 with one 8-pin connection can draw a MAXIMUM of 225W on its own (75W from PCIe and 150W from a 6+2 pin connection) and aftermarket cards with more power connections still won't allow the card to draw much more than 225W on its own.
Your 4690K is a very power-efficient CPU and might draw 150W if you overclocked the snot out of it.
So to suggest that a 500W unit of decent quality is "risky" is silly. It's literally impossible to draw that much with your current hardware + 1080.
