Does Ryzen Get Stuck?
2 minutes ago, Mike Soda said:Thank you so much, I'm going to bed now but here's my game plan. Reduce the fan speed & run Aida64 Extreme while OC'd to hit about 80C. I'll then try to quickly disassemble everything before it cools down & use your very slightly twisting method to ensure it's loose before pulling. If that doesn't work, so long as I completely power everything down & disconnect, would it be safe to squirt 91% Isopropyl Alcohol between the chip & heatsink? Also do you have any other minimally risky methods?
I'm personally not a big fan of this soaking method, generally it should work, but even though it's only isopropyl alcohol it might damage plastic parts on the motherboard (if you have an acrylic window on the case it can cause microcraks fairly easily, too) leave stains on painted objects and so on.
As long the themal paste is not ancient old the whole heatsink removal is fairly unlikely to cause any issues, also a "pulled CPU with heatsink" is not damaged at all in most cases. Slightly bent pins are very easy to fix and ripped pins by sticky heatsinks are maybe case by one of a 1000 of those who pulled their CPU and heatsink together.
Ryzen is a young platform, warm paste has a lower viscosity I think you should be fine. Just don't rip, pull and twist the whole thing like a jackass than should nothing get damadged.
BTW so far I removed (changed) my Ryzen CPU heatsink now in my system 3 times and replaced the heatsink in the Ryzen system of a friend once and so far I didn't pulled it out of it's socket, so I guess it's less of an issue on this platform.
