Fixing a blown out speaker
79wjd
My left speaker is no longer working -- if I play content I hear it perfectly from the right speaker, but the left speaker sounds like a quiet whisper. I noticed it after I accidentally had the volume set to max, so that's why I think something blew. The speakers are M-Audio AV30s and I already emailed their support to see what my options are, but it's out of the 1 year warranty, so I don't expect anything to happen there.
Anyway, what is likely the problem/is it fixable? I plan to open the speaker up and see if I can see any damage after I hear back from their support (if they say they won't take care of it for free).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
How do you know it's blown? Did you play it too loud?
it could be a failing weld inside the speaker. Could be a bad wire if it's a poor or cheap design.
go into sound manager and make sure audio is centered between right and left
check all physical knobs as well
I ran a speaker test (that plays audio to each speaker independently), and all the settings are normal/as expected. The left speaker is nearly silent while the right speaker sounds normal.
PSU Tier List | CoC
is this a 3.5mm stereo plug to speakers(how does speakers get signal from pc)
3.5mm to right speaker, and then speaker wire from the right speaker to the left speaker.
PSU Tier List | CoC
3.5mm to right speaker, speaker wire from right speaker to left speaker.
try rotating 3.5 plug(twisting it) and see if left speaker comes back
make sure this plug firmly seated (see bing images for these plugs pin outs) to do continuity tests of left channel(also known as mono)
have you physically looked at speaker yet?
I haven't opened up the speaker yet as I'm waiting to hear back from M Audio support -- I didn't want to potentially run into issues with them if they did decide to help even though it's out of warranty.
PSU Tier List | CoC
I opened up the speaker and took what pictures I could.
PSU Tier List | CoC
you may have truly blown the speaker as these are self ampliphied(powered) speakers and almost all the mobo today are powered outputs(easy to over power speakers)
why i have my audio go thru hdmi to my display then from displays headphone out(headphones are passive circuit) to my creative labs 2.1 speaker box (5" woofer with left right stereo chans)
this why windows has audio settings for head phone, small speakers, large speakers is to know how much power to put into audio outputs
irregardless of speaker configuration (2.0 2.1 4.0 5.1 7.1 etc)
other than a hair on transformers backside of pcb with discolorization to pcb at transformer(electroplating the pcb with copper atoms from over currenting the transformer) im not seeing any thing wrong with hardware
is speaker wires still attached at speaker itself(is cone wires ripped from cone)
2 hours ago, bcguru9384 said:
<snip>
That is the biggest load of horse shit I think I've ever read. Not a single thing you said there is in any way correct.
The wires between the board and the speakers are connected -- if they weren't connected I wouldn't be able to hear any sound.
PSU Tier List | CoC
bump
M Audio support has told me to contact a third party service center....and I highly doubt it's going to be a price that makes any sense. So any thoughts on how I could go about finding and then fixing the problem?
PSU Tier List | CoC
please tell I where and why i am in correct
please prove your statement
well grab a multimeter and probe the circuit paths as we have already
A. checked sounds left right balance
B. eyes inspection of pathways
now its probing time as we do not have ability to read driver code scripts to see if an error has occured there(although windows event viewer should show some data)
The amplifier in the speaker will be matched to the drivers, or more likely slightly underpowered, so it's usually not possible to blow the drivers in them. (And you would hear the driver distorting before it went).
Secondly, all outputs (bar those from some turntables) go through some amplifier or another. Those on computers are meant for headphones or at maximum line level output. This is the level powered speakers are designed to receive. No motherboard will have outputs designed for directly driving speakers.
Headphones are passive but the outputs are most certainly actively amplified.
Windows has settings for small/large speakers or headphones because it changes the eq on the output for each (not that that's a great thing). It outputs at exactly the same level for each option.
There will never be a transformer inside a speaker (thus it can't be 'over-currented', and would simply melt to a solid block rather than reaching temperatures needed for electroplating). The wires would be soldered to the ends of the voice coil, so would have had to have been physically ripped to be disconnected. Also, the term 'blown' traditionally refers to an ejected voice coil, rather than just a broken speaker.
Why would event viewer show anything about a hardware issue in the speaker
And I don't have a multimeter with me -- I would have to bring the speakers home -- but if one of them is dead to the point where it's not an easy/feasible fix then I'm not even go to try to bring them home (on a plane).
PSU Tier List | CoC
I suppose I should start helping...
So the unpowered speaker is either really quiet or not making any sound, but we can (largely) rule out component failure. You've made sure all windows settings are correct and used a variety of software with known good content to eliminate it being a source issue.
One last thing to check on the speaker itself is that the driver is moving freely, if you gently press on the front of the cone it should move cleanly and return to it's original position. The risk with overpowering drivers is that the voice coil will melt (and jam) or it will be ejected from the magnet.
If you swap the inputs around does the other speaker become quiet/not working?
It's a 3.5mm from the computer to RCA on the back of the speaker -- so I've tried flipping the red/white connectors around, still no sound from the left speaker. The cone does move freely and I pulled out the driver to see if anything looked bad around it, and it looked fine. However I did notice that now I hear static from the left speaker, which I didn't hear before (at least I don't think I heard it before -- but it is somewhat loud in my apartment, so it's possible I just missed it).
I attached a video below -- the first sound is the bad speaker at max volume, the second sound is the good speaker at about 25% volume, and the third is the bad speaker at the same 25%. (The speakers are next to eachother, so the relative sounds are absolute).
IMG_3562.mov
PSU Tier List | CoC
I think for the price of the speakers its probably not worth your time. Probably a better idea to look for a second hand one to just replace the broken one.
I wouldn't put a lot of money into since they were cheap, but if there's an easy/cheap fix then I'd definitely try and attempt it.
PSU Tier List | CoC
  • 2 weeks later...
@anothertom Any ideas/guesses as to what's wrong?
PSU Tier List | CoC
It could be a loose connection on the driver, it could be a breaking cable somewhere else.
If it's not obvious then it's probably not worth the effort.
Speaker may have seized. How long did they run at max, what was playing, were they distorting.
Not that long. I was trying to drown out my roommate, but I was more annoyed with the loud speakers in front of me then his loud nonsense. I was watching a movie. No, but there might have been a pop sound (that's also when I lowered them) -- but it also might have been part of the movie.
PSU Tier List | CoC
