[SOLVED] Any problems if I land my brother my M.2 for... FPS reasons?
Your boot order will play the role for which windows copy it boots from. You'll essentially have two systems on one computer, the first boot device will determine which system to use.
So in your case, boot via his HDD for his system. Then pull up the M.2 in disk management, you will notice there is a partition already made for your copy of windows you have on it. Create a new partition in the empty space for his PUBG copy.
When you're done, just remove the partition you created and put it back in your PC.
As per the FPS issue, it's not HD related, HD's affect load times into the game (loading screens). FPS is directly related to CPU/GPU usage. Stuttering and lag will be network, RAM, or CPU. Open task manager and see if you memory, CPU, network, or hard drive usage is spiking. If none are, GPU may be at fault.
