my budget is around 140 USD
im looking for a case that will allow the graphic card to breathe and that will fit the Noctua NH-D15.
would like the most quiet case possible
My Spec:
I7 7700K
Cryorig H7 (Soon
Noctua NH-D15)
Gigabyte GA-Z270-HD3
GTX 1080TI
16 GB Corsair Vengeance LPX 3200 MHz
WD Blue 250GB SSD
1TB WD Blue
P2 650W PSU
https://linustechtips.com/topic/853086-case-for-my-spec/
10 minutes ago, Damascus said:
Meshify C
Or Enthoo Pro M TG
You'll want lots of good uninhibited airflow, and these cases are the best at their prices for it.
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10627333
15 minutes ago, _SAITAMA_ said:
Also my suggestion is to add 16gb of ram so that is 32 in total
and get an M.2 if mobo supports (512 gb ones are better)
Or a bigger SSD
  Why tho...
The RAM will only make a difference in rendering and stuff and m.2 really won't be a noticeable difference, it will also just subtract from the case budget, which matters more.
On topic: H440, S340 /Elite, R4/R5 etc. You really can't go wrong with this budget, just pick one you like and check with the forum before buying. Good luck!
That's an F in the profile pic
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10627347
Just now, Froody129 said:
  Why tho...
The original H440, S340 and SD340 elite dont have good enough airflow to keep such hot hardware cool. R4/R5 are solid. I've heard the H440 "V2" fixed a lot of airflow issues
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10627356
I have the H440 V2 and love it so I'm slightly biased xD. As I said though, most any case in this price range will be excellent and you can just check with the forum that it's a good choice
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10627373
2 hours ago, aloneng said:
You should spend money delidding your CPU instead of buying a better cooler, you need to fix your TIM issue more than just getting a larger cooler possibly.
a Master Case 5 is pretty good
https://www.newegg.com/Product/Product.aspx?Item=N82E16811119316&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
The Thermal Take Core X9 has all the room in the world to play with.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811133275
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10627440
i aware about the Tim problem, i preffer to delide after my warranty will end (my old i7 died in the warranty time once),
anyway, forgot to mention that im looking for Full Tower Case, That will be the most quiet as possible (would like case without a window), that will fit Noctua NH-D15.
Edit: Also a case that will be high, not wide (will be under my desktop).
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10631050
I'm saying it won't matter so much if you slap a giant cooler on it, without fixing the TIM first, you don't even have to use liquid metal.
You can pay Silicon Lottery to delid it, known a few people who've done that
https://siliconlottery.com/products/delid
I don't think too many people make giant tall cases anymore, likely wasn't too much money in doing so. The mastercase 5 should fit everything and will be pretty good on airflow, but here's a big list from Gamers Nexus's testing,cooling performance is on the bottom for a CPU+GPU test, there's more on the page itself.
https://www.gamersnexus.net/hwreviews/3081-cooler-master-master-case-h500p-review-poor-quality-and-airflow/page-2
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10631190
i aware about sillicon lottary, its just that the shipment will be around 100 usd for both ways (and i will still need to pay to them for the service), i preffer to delide after the warranty will void by myself... anyway I was not the most completely clear with that i asked for tall cases, i wanted to mean for Full tower cases. btw, what you think about panzer max by couger? and there is somthing similar to that just without window (the side will face a wall) or somthing better in the price range.
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10660295
25 minutes ago, aloneng said:
If that's the kind of case you want just buy it
You might also want to consider the HAF XB EVO, or ThermalTake Core X9
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10660460
the computer will be in tight space, so im looking for somthing that is big, but not wide... if you know somthing such as the panzer max, but without the window , it could help.
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10660548
If you need full sized ATX look at some Lian Li cases, otherwise you might just want to go ITX with your system.
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10660560
Dark Base Pro 900
  • Quiet
  • Silent
  • No window
  • Fits NH-D15
  • Tall, not wide
https://pcpartpicker.com/product/G34NnQ/be-quiet-dark-base-900-black-atx-full-tower-case-bg011
be quiet! DARK BASE 900 ATX Full Tower Computer Chassis - Black
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10660613
9 hours ago, TVwazhere said:
Dark Base Pro 900
  • Quiet
  • Silent
  • No window
  • Fits NH-D15
  • Tall, not wide
My motherboard is ATX , and i know that Lian Li got some nice cases, but i can't get them in reasonable price.
same goes for the dark base pro 900 that is what i looked for.. the price that after taxes and etc... will cost me around 350 $,
way out of my budget (140$).
im looking for somthing simillar to the dark base pro 900 just in my budget.
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10660745
Pure Base 600
https://pcpartpicker.com/product/PNTrxr/be-quiet-pure-base-600-atx-mid-tower-case-bg021
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10660776
8 hours ago, aloneng said:
Just buy the case you were looking at earlier if your options are limited, it seems pretty solid, you could always just cover the window potentially if you don't like it that much
https://linustechtips.com/topic/853086-case-for-my-spec/#findComment-10662808
