how friendly is doubblesided foam tape to motherboards and electronics?
Solved by Bananasplit_00,
ok well thanks for all the info, good to know and feel free to note more things but looking through my pile of cases i have found another one id like to use for something and this is actiually pretty much perfect
1 minute ago, ARikozuM said:Go for it. As long as you're not working on a 9590, you should be good with that heatgun!
its an FX chip but not that monster, anyway i found another fun case to use for it among my storage under my desk, but all this wasent in vain because i will probably have quite a bit of use of it in the future
