19 minutes ago, Sychicyuto said:
I have a case Msi mag 112r
How do i control installed argb fans
My mobo is asus prime b660m-a wifi II D4
I have connected the rgb hub on the back to the mobo
if it was icue use icue but if it is msi don't use msi center. You can try using singal rgb or open rgb. MSI center is pure snakeoil.
https://linustechtips.com/topic/1569042-rgb-control/#findComment-16398596
The motherboard isn't msi motherboard asus and the case fans are preinstalled in case case is MSI MAG 112R
https://linustechtips.com/topic/1569042-rgb-control/#findComment-16399474
