Best g sync monitor under 200
Fadednova
Can someone link me a (if possible) g synch compatible monitor under 200 that ships to austria
Don't think there is one
Want to custom loop?  Ask me more if you are curious
Does not exist. The cheapest G-Sync monitor is $321
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
than the best monitor under 200
1 minute ago, Glenwing said:
AOC G2460PF
Our Price: EUR 224.06 on amazon
buy two broken ones and make a single good one out of them.
one rule in austria do NOT buy used because everybody doesent know the prices
hello?
Just now, Fadedboy said:
yeah used in austria is a nono
ok that's twice that you've typed that now...
best under 200 (in USD) for me its between the VG245H which is 75hz or the G2460PF which is 144hz. Both are 1080p and honestly depends on what you want in your monitor.
the 75hz is an Asus monitor which includes their whole eyecare flicker free thing
the 144hz is an AOC monitor and the brightness at stock is WAY high. PcCentric reccomends the 2/100 setting. yeah, Two.
Otherwise theyre similar is every other aspect that matters
Edit: Gsync by itself adds $200 USD to the price of almost any monitor so if you really want gsync, be prepared for a minimum of $300 (again USD)
  • CPU
    Ryzen 5 1500X
  • Motherboard
    ASUS Prime B350-Plus
  • RAM
    1x8gb Corsair Vengeance LPX
  • GPU
    PowerColor Red Devil RX 580 8gb
  • Case
    Phanteks Eclipse P400s
  • Storage
    Samsung 960 Evo 250 gb
  • PSU
    EVGA SuperNOVA 650W G3 80+ Gold
  • Display(s)
    AOC G2460PF
  • Cooling
    AMD Wraith Spire
  • Keyboard
    Corsair K70 Rapidfire
  • Mouse
    Logitech G502 Proteus Spectrum
