Help cloning my hdd to my ssd.
Solved by JoshieBobba,
Nvm Google is your friend
What SSD do you have? If you have a Samsung SSD, you can use Samsung Magician to clone it. Clonezilla is also a good choice.
Hyper x ssd. Got it today. I figured out a better way to do it Thanks anyway!
Citrusflavour01 ·
Posted in Laptops and Pre-Built Systems2 -
5
tomatensaftliebhaber027 ·
Posted in Peripherals3 -
Alaz ·
Posted in CPUs, Motherboards, and Memory1 -
frvgii ·
Posted in Graphics Cards2 -
1
Gat Pelsinger ·
Posted in Linux, macOS and Everything Not-Windows4
